When I open the ratchet tool, I can only see a Geneva gear. Am I missing something? I need a plain ratchet to make a ratchet and click system for my clock project. There's a ratchet available in GM though.
Steve
Ratchet types in GT
Re: Ratchet types in GT
Steve,
See if clicking "Gravity" below the Geneva is what you are after.
Stephen;
Ken is right, select the gravity tab to generate a more familiar ratchet type, cw/ccw will change it's direction, and you can adjust the actuator lenght and/or the depth of the tooth face where the ratchet will lock. Hope this helps.
Stephen Fornelius
Yep, that was the answer. Gives me an interesting pawl design too!
Thanks for the help.
