Need Advice on how to accomplish movement
Posted: Mon Mar 16, 2020 8:42 am
I want to construct a machine that will rock an item about 270 degrees. Can someone point me to what might be the easiest way to accomplish this?
Specifically I am trying to construct a device to hold .3x.3x70" strips of bamboo (fly rod splines) that nodal areas need to be moved over a heat gun back and forth about 2" and rocked so that 3 sides are exposed to the heat. And the two movements need to be none synchronized/repetitive. Preferably using a small DC motor. The back and forth I get but the rotation past 180 to 270 is my challenge.
Hope I explained it well enough.
Any thoughts greatly appreciated.
RT
RT
