Lantern gear pinion question
Posted: Thu Mar 06, 2014 11:35 am
Hi Folks - newbie here
I recently purchased this amazing software and have been designing up
an external Lantern type gear train. My question is of the accuracy of the tooth depth.
I noticed that after "creating" the pinion and wheel, there is a small gap at the bottom of the tooth where
the pin should seat into the radius. After measuring, it looks like about .033" of space which doesn't show up in the original
gear layout under the "lantern" tab. I selected a zero backlash in the pop-up dialog box before generating the gear model so I assumed that
the pin-wheel and pinion would fit together air tight (for registration purposes) Any thoughts? Also - after comparison to a cad generated model
using the same geometry, there is a distinct .033" difference between the pitch diameters.
(The blue model was generated in Gearotica, Orange - I hand modeled up in Inventor using geometry I found in an old machinery handbook of gearing (1916)
any thoughts would be great. If i commit to making this pinion out of metal, I really want it to run smooth.
Cheers! - JD
Cheers! - JD
