Page 5 of 7
Re: Orange Clockwork Ticker
Posted: Wed Feb 22, 2017 9:09 am
by Rocket
Ignore my last question: I figured out how to convert mm to inches in Cut2D desktop.
I assume I can change your bottom plate to my own "hub" from
one of my spinning wheels, is that correct? I guess I would have to tinker
with spring size and weights to achieve proper wheel spin. Do you think
your set up would drive one of my two wheel spinners with a 40 inch diameter and 12 vanes
on each wheel?
Richard
Posted: Wed Feb 22, 2017 10:03 am
Richard:
I suspect it would, you might have to remove 4 of the pins, so it really has a fair amount of kick.. always
hard to say though without trying it..
Posted: Thu Feb 23, 2017 5:45 am
by Dan Mauch
Thanks Bob that what I was thinking.
BobL wrote:
Dan;
The more pins you have the slower it rotates, in other words the less of a kick it gets between pins.
Posted: Thu Feb 23, 2017 11:54 am
by Rocket
In the files you posted you refer to top and bottom (in the jpg pictures).
Is the top the front wheel and the bottom the back wheel?
Richard
Posted: Thu Feb 23, 2017 12:02 pm
by Rocket
In the photo below that you named spool.jpg.
Is that 3 pieces of wood glued together?
Richard
Posted: Thu Feb 23, 2017 3:18 pm
Hi Richard:
YEs, I refer to top as the front rotating panel, and bottom as the rear. The spool is actually 2 pieces. The main spool has a ring
machined into it, and a second ring was pocketed to fit into the main spools ring, together they make the takeup spool 3/4"
thick to hold the spring as it winds on. That way I didnt have to glue on the second half of the ring, I justr pushed it into the machined
ring and glued it..
Posted: Fri Feb 24, 2017 2:23 am
by Rocket
What is the length of the eight brass pins?
Richard
Posted: Fri Feb 24, 2017 2:35 am
Richard:
They extend to 3/4 inch out of the spool, and press through to the other side
of it flush
Posted: Fri Feb 24, 2017 8:25 am
by Rocket
Sorry to bother you so much.
Why does the ratchet latch have to be notch out?
I cannot see any dimensions for positioning of magnet on the crescent bar?
Do I just position the magnets the best I can as per photos?
RR
Posted: Fri Feb 24, 2017 10:12 am
by Rocket
Why does the RatchetLatch.dxf look different than
the latch(3).jpg?
Richard
Posted: Fri Feb 24, 2017 10:48 am
Hi Richard:
The shape of the latch is one of those things that I modified as I built it.
I decided to make it quite thick, and the ring spool doesnt match the hight
of the crescent shaped holers, there is about 1/4" difference, so the ratchet
trigger is nothed out to follow around the curve of the spool disk when its
engaged. This keep the latch body from hitting the disk.
The magnet I use as a spring is about 1/2" from he shaft of the latch,
you can vary this to any confortable spot, but approx. 1/2 inch from
the shaft allows it to make a good spring for the distance it will have to swing
outward when pushed. The only importance to the distance is that the magnet
still have enough power at that point to swing it back in..
The other magnet I just used as a glide to lower friction on the latch
as it swings in and out. The Latch and the toggle you can expect to be a
bit different from the drawings as I modified them slightly as I built it.
Notching the trigger toggle for the bar magnet is a bit of a job, as youll find
as you try it.. I ended up holding mine on my router and running a groove in it,
then expoxying a magnet into the groove.
Posted: Sun Feb 26, 2017 10:32 am
by Rocket
Did you have to try many different types and strengths
of magnets before you hit on the right combination?
Richard
Posted: Sun Feb 26, 2017 11:13 am
Richard:
No, you ll find the neodyniums are pretty good, I used 1/4" round x 1/4long cyclidrical ones, and a few 1/2" x 1/8 or so round discs.
I got mine at Lee Valley, but ebay'd be an easy spot to get a bunch..
Posted: Mon Feb 27, 2017 1:33 pm
by drezal
Cool design. I've spent hours watching David C. Roy's stuff spinning around and every time I think I'm close to figuring out how to do it something doesn't quite work. I'll have to try this out, Art.
Also - could another way of slowing or speeding it up be by changing the sizes of the wheels? Say a larger pinned disk and a smaller spring wheel?
Posted: Mon Feb 27, 2017 1:40 pm
by drezal
And one other quick thought/question that might make creating this even simpler... it seems that the little diamond shaped ratchet as well as the larger arm would be perfect things to 3D print. Hmmmmm
I built a small and dirt cheap 3D printer (~$175) that has been great in the shop. It has made parts for a CNC build as well as other odds and ends. It might play really well with creating kinetic art projects.
