Auggie Not responding to G01
Posted: Mon Feb 29, 2016 4:45 pm
I'm setting up a PoKeys57CNC with Auggie. I've groped my through the PoKeys User Guide and subsequent hardware configuration and watched many YouTube videos
The network connection is done and Auggie talks to the PoKeys through either the USB port or over the network. Success!
The motors all jog and G-code rapids all work within Auggie.
However, no entry method that contains a G01, G1, g1, or g01 will run past that point. Did I set a persistent mode somewhere by running one of my Mach3 .tap files. During MDI the continuation LED flashed when I press STOP (after code execution halts, without error at the G1) Any motor movement code on the line is not executed.
Here is the preamble I put in the Mach3 files:
G00 G17 G20 G40 G49 G50 G64 G80 G90
Thanks for your help
