Bearings in clocks
For the makers of various third party clock designs..
Re: Bearings in clocks
The start of a new service, the Gerotic Delivery Net?  I didn't think of it this time, but if they drag me off on another expedition.  The youngest girl (the one I owe an international trip to) is starting to hint about South America.
I can't be the only one who's wife wants to turn into a global traveler; perhaps we need a pending international request and delivery list.  Likely slower than Kickstarter but less likely to fail :)
I’ve just completed David Atkinson’s Sextus design and it is the first clock that I installed steel bearings. Although David has bearings in several locations I only installed them on the pendula. Since the escapement is a grasshopper type it is highly sensitive to the drive weight to regulate the time, I found that sufficient weight to maintain the running of the clock meant that the clock was being overdriven. By installing the bearings in the pendula I was able to use a much more acceptable drive weight, and thus more overall time accuracy.
Here is a picture of the finished clock.
Awesome work. I agree totally with you, a bearing can do wonders for almost any work, and I
really advise using them when one can. Merry XMas and thx for showing us your work.
Hessel Oosten
Post by Hessel Oosten »
Really wonderful clock John !
Once I did read that bearings give a 70 % reduction in resistance, in comparison to fine polished (e.g. steel in bronze in clocks) pivots.
Hessel
kit
Post by kit »
That's a nice example of the Sextus. It's a very hypnotic design to watch!
I was surprised at how much difference there is between ball and plain bearings. Soaking them in solvent to remove any manufacturer-installed grease apparently helps as well. At the speeds we run these bearings, grease and oil simply add drag.
