Tangential Saw 4th Axis
Posted: Sun Feb 15, 2015 2:21 pm
Would it be possible to now include slitting saws in the 4th axis toolbox?
If you are working in metal and wish to use none profile cutters, then fine slitting saws are about your only option.
As we have discussed previously, preferably a uni directional cutting option too.
Also no A axis rotation when the cutter is potentially in the work-piece, this happened in some versions as Gearotic expects the cutter to be clear in a longitudinal direction, not possible if trying to produce a stick of pinions.
I don't fancy trying cutting 90 plus teeth 0.55 module in brass with a 0.6mm end mill!
Great work
David
Great work
David
