Program Frozen after entering "0" value for pinion tooth count.
Posted: Tue Jun 09, 2015 7:42 am
Today is my first day with Gearotic and it is amazing. I'm also really enjoying the YouTube videos (Narrator is excellent!)
I found that I was able to freeze the program by entering "0" value for pinion tooth count. (I think entering the number "1" also had the same effect).
I am trying to make a double spur gear with a spacer built into the top and bottom of the stack. So I decided to try and make a gear with zero teeth to place on the bottom and top of the stack to serve this purpose as a spacer.
I'm watching "ClockTutorial2.mp4" now so I'm guessing that I need to export to a cad program to add spacers, but I'm still learning so I'm not too sure.
I'm a newby so I did not realize that saving a file will save only the "project" area and not the gear I had set up in the "tools" pane. Or was this because I was unregistered when I saved my gears this morning - not too sure. (I never made it as far as moving the gear to the 3D workspace).
I am using version 2.229 on Windows 7. -I will re-boot and re-install and try it again.- all best!
