Help needed on modifying a saved project
Posted: Tue Mar 22, 2016 5:46 am
by akeller
In would like to modify an Gearotic2 project with 3 non-circular logarithmic wheels and add a fourth identical wheel.
The project was saved some time ago.
When I open that project now, i do not see the orignal gear definitions in the properties window (Tools tab). That means i cannot retrieve the values for ?Gear Size Ctrl?, ?Pressure Angle? and others.
Those values are not displayed in the ?Project? view tab when the wheel is selected.
How then can i create and place another identical wheel to those that are already in my project (using button 'Create Wheel')
As soon as another non-circular logarithmic wheel is defined, some of the definitions of the previous wheel cannot be retieved any more?
I have reloaded the backup of gearotic root folder including all project files, but the original definitions are still not available.
Thx for any help, Alfred
Re: Help needed on modifying a saved project
Posted: Tue Mar 22, 2016 6:35 am
Alfred:
Load your project and press "Project Summary" on the properties tab, youll see a list showqing the
noncircular parameters used..
ARt
Posted: Tue Mar 22, 2016 7:19 am
by akeller
For an exact duplication of a wheel, i would also be interested into the Spoke parameters and the Shift/Stub/Width parameters. Would those also be available in the projects file for including in the Project Summary output?
Alternatively, a hint in the documentation might be helpful that the user should write down those values manually or take a screenshot if he wants to be able to easily reconstruct an identical wheel in another project.
Thank you for your patience, Alfred
Posted: Tue Mar 22, 2016 7:55 am
Hi Alfred:
  Im not sure the spoke type is kept, but I can modify it to put out
shift/stub and width. The data is in the file so you should get access on next version.
Ill post a note here when the mod is done.
Posted: Tue Mar 22, 2016 8:00 am
Hi Alfred:
  As of next version the shift and stub for noncirculars will be included in the
project summary. The data is still in your project, so youll get access to it without
redoing the project.
