Error with Belt Length Calculator
Posted: Tue Jan 29, 2019 10:57 am
I used the Belt Length Calculator that is part of the pulley subroutine to come up for the center distances for a belt drive. When checking the results against the work of another person who did the same calculation using the belt length calculator on the Westcoast Products website, we came up with substantially different answers. We did a simple calculation by hand using two 30 tooth HTD pulleys and a 160 tooth HTD belt having 5mm pitch and came up with 11.811 inches, whereas the Belt Length Calculator came up with 11.694 inches, which is almost exactly 99% of the hand calculated distance. When comparing results with the Westcoast Products calculator, the Gearotic center distances are 99% to 99.5% shorter with the difference being greater with longer belts. Is this intentional?
