90 degree pin gears
Posted: Tue Feb 17, 2015 1:42 am
by Ian
As you was so fast with the "rythmic geneva gears" something perhaps a bit more challenging
I only work in wood mainly using a laser cutter I would like to achieve a 90 degree drive using two cage (pin) gears
Length of pins would need to be specified I guess
Hope that makes sense
Many thanks again
Ian
Re: 90 degree pin gears
Posted: Tue Feb 17, 2015 2:37 am
Ian:
  Already in my list..but since you can now make the gears, and the pin length is more a function of the build rather than the design, it wont come fast. Its one I consider as Possible to do, but not possible as yet to simulate. :)
