Page 1 of 4
Release update
Posted: Fri Nov 17, 2017 6:48 am
Gearotic has been updated and a video "Intro to Vexx" has been uploaded
as a brief introduction.
https://www.youtube.com/watch?v=Lmrpok3JLnE
This is a beta version of Vexx, and further videos will be uploaded in coming weeks
to explain the way it works..
Re: Release update
Posted: Fri Nov 17, 2017 9:34 am
by drezal
Awesome. I'll have to find some time this weekend to play around with it.
Re: Release update
Posted: Fri Nov 17, 2017 2:30 pm
by John T
Is this a general problem or just my Mac?
Re: Release update
Posted: Fri Nov 17, 2017 5:14 pm
First Ive seen of it, it runs on all the windows machines Ive tested it on, but it is compiled under Win10 compilation tools. ( Though I run Win7 myself.).
Lets wait a day or two and see if anyone else has the same issue.
Re: Release update
Posted: Sat Nov 18, 2017 3:35 pm
by steve323
It runs on my Windows 10 laptop, although I have only tried a few commands so far.
Steve
Re: Release update
Posted: Sat Nov 18, 2017 3:41 pm
Steve:
Thx, good to know its working.
Re: Release update
Posted: Sat Nov 18, 2017 9:45 pm
by Rocket
Where do I find the link to download Vexx?
Re: Release update
Posted: Sun Nov 19, 2017 1:37 am
Hi Rocket:
Just download the development version fo gearotic, Vexx is now included.
Re: Release update
Posted: Sun Nov 19, 2017 8:40 am
Just and update, another video has been posted at
https://youtu.be/Z3NqiIdVM38
to explain the operational theory behind Vexx..
Re: Release update
Posted: Mon Nov 20, 2017 9:21 am
by drezal
Very neat stuff. So, here is my first question, forgive me if it is a stupid one.
Since Vexx can import a gear design from Gearotic, all lined up neatly in a working set up, would it be possible in Vexx to design a creative box around the arbors and then just export that box design for the CNC? I've used the box function before in Gearotic but am wondering if it would be a cool way to design a unique box structure? As far as lining up the holes in Vexx, I guess circles could be simply placed over the holes?
Re: Release update
Posted: Mon Nov 20, 2017 2:57 pm
Hi :
No such thing. :)
>>Since Vexx can import a gear design from Gearotic, all lined up neatly in a working set up, .... up the holes in Vexx, I guess circles could be simply placed over the holes?
Basically, yes. The easiest way to do that would be to import all the gears in the project to vexx, then draw your boxing design around them. Delete all the gears except their shaft holes, that way your shafts will all match up. At that point all you'll have on the screen is your design with shaft holes. Send it to gearotic by replacing one of the gears, ( the one at 0,0 center) and
then you can send it to 3d workbench if you like or save it as a stl.
One note, when you make the gear at center which youll use to be replaced with your boxing design, give it a facewidth equal to the thickness you want the boxing design to be. You cant
set the end thickness in Vexx (yet), it will be as thick as the gear its replacing
Re: Release update
Posted: Tue Nov 21, 2017 3:43 pm
by drezal
Cool. Thanks.
As a side note...since I've downloaded the most recent version of Gearotic I keep getting Improper Shutdown Detected. I clicked no the first time I got the warning and it worked fine. Then the next day I got the same warning and the program wouldn't run. I get the notice that Gearotic 2.0 has stopped working. Hmmm. I've uninstalled it and reinstalled it and keep getting caught up in this loop.
Re: Release update
Posted: Wed Nov 22, 2017 1:47 am
Hi Dan:
Sorry about that, I havent seen that effect as yet. In most newer Windows versions if it
sees an error on exit it restarts the program. There is a windows setting for that somewhere..
Ill keep looking for such an error. Does it happen every time, even if you open, then close immediately?
Or does it take some kind of action to make it occur?
Re: Release update
Posted: Wed Nov 22, 2017 9:10 am
by drezal
Hey Art,
Well, the first day I downloaded and installed the Vexx version it worked fine. I tinkered around for a while, it was late in the day, and then closed out of the program. My computer is on 24/7. The next day I went back to open it up and that's when it wouldn't load. So, I uninstalled it and reinstalled a fresh download and still had the same problem, wouldn't run. I then uninstalled it and installed the prior stable version and that version seems to work fine.
Since nobody else has complained it is probably something I'm doing, just not sure what.
Re: Release update
Posted: Wed Nov 22, 2017 1:18 pm
Its young, such problems will work out over time Im sure..they always do.. :)
