Split Ring Planetary module
Posted: Sat May 17, 2025 5:09 am
In the latest version , in the program Spur, you will find a button to switch to planetary gear mode, where you can design the dxf files to be used in programs such as Fusion 360 to design a split ring planetary gearbox of various ratios and diameters. I will be adding a video shortly to explain how it works, and how it can be used to deign hi ratio stepdown gearboxes such as the one in the photo, which is 51:1 , being driven with a small gimble motor as a test. This module does not generate any stl's, it is used only to generate the dxf's for use in building the rest in whatever CAD you wish to use. I use Fusion 360 and it wasn't hard to design the one shown, which is small as I wished to press my luck.
Regards
Regards
