version 2.30011 online
  Gearotic version has been updated for a bug in the functional gears , the teeth were not being clipped
properly to the addendums. This should work much better now.
BillM
Re: version 2.30011 online
Post by BillM »
I just downloaded the latest version from the website.  When I check the ? box to verify the license, the version number shows 2.30050 not 2.30011.  I am confused.
Bill
Hi Bill:
  Did you download the development version? And did you install it in the same place, ( off root folder?)
BillM
Post by BillM »
I selected the link under Current Stable 2.2990 ::  Here is a copy of the link
http://www.gearotic.com/linkcnt/click.php?id=3
  For current version you want the development version under that link. The stable version is updated
only periodically so that bugs I may introduce in development are found before it gets updated.
Current version is under Dev. link..
BillM
Post by BillM »
Thanks for steering me to the correct link.  The version the "?" screen shows is 2.30110 instead of 2.30011 which I assume is simply a typo in the help screen (see attached image).
Before I install a new version I always first uninstall the old version using IObit's Uninstaller program which also cleans out references in the windows registry.  I install to a disk partition that is separate from the default C: windows drive & I logon as administrator which eliminates most permissions problems when running programs.
The new version that I downloaded today exhibits the same behavior that I mentioned in a separate message to your ArtF inbox a couple of days ago.  Video Rec & snapshot both result in a blank white capture on the computers running Windows10 (a Dell 1557 notebook, and a Lenovo Q190 desktop).  Video Rec & snapshot record correctly when I boot the systems to a Fedora 23 Linux and run Gearotics2 using Wine.  The 1667 error still does occur when trying to select a CODEC (e.g., fddshow) on both the Windows & Linux OS's.
This is definitely a Windows 10 problem with some weird combination of the Video card driver & the Video For Windows interface that I believe Gearotics uses to to the screen captures and recording.
I think I'll return to looking through the forum topics and studying your tutorial videos on Youtube.
Thanks for your help,
Bill
Hi Bill:
Yes, thats current. VFW is a bit strange, and has been known to be buggy on some systems. I haven't supported Win10 yet as I haven't tested the various functions. I may look at updating the VFW to some other interface in future
specifically for Win10..
oh, I might mention as well,  to uninstall Gearotic you can just delete the folder, or to install a new version, just install over the old one. I dont use techniques that screw up registries in general.. or install drivers or other runtimes,
so I just reinstall over the program, and have done so thousands of times with no ill effects.
ARt
Users browsing this forum: No registered users and 159 guests
