Maynard:
Some of the API's did change and they may be causing a loop. When you get a chance, see if you can figure out which one it is and send me the library..I can probably stop the loop..
MaynardC
Post by MaynardC »
I added the folders back to the script folder one by one, starting with default Auggie libraries, than onto my custom libs. Ran fine at each step, and now loads fine back at the original state. Sorry to interrupt this thread, but all seems fine now.
Maynard
No sweat:
  It may be it simply was resetting to some new defaults. Ive been adding many fixes and reliability updates as I use it and find things that annoy or don't work.
Re: Wiring the 57cnc
Thought Id show my wiring.. for those that have asked about plugs and such..
DanL
Post by DanL »
Hi art M30 is still not working the log does not show anything, I ran with the scripter open it comes up that it is blocked.
I ran it with a couple different G codes
Hi Dan:
  Thx, Ill keep trying to find out why, M30 works here with no problem.
  Im curious, if you put a line after the m30 , does it get executed?
DanL
Post by DanL »
yer I tried that M5 then M30 no different even had M5 go to the Axis zeros then M30. it stop's 3 lines before M30. new profile as well.  I have to have a sit down with the machine and see if I can find it my end, but I have a router to go fix some one did not watch where they where walking
  Are you sure it updated to 1.45? It did used to stop 3 lines before the m30..
DanL
Post by DanL »
yep just checked I will do a uninstall and reinstall see if that helps
DanL
Post by DanL »
reinstall did not help
Never does.. Nothing I write usually needs a uninstall..
hmm, ok, Ill run some tests to see if I can see why. Anythign special in the
program or does any sequence ending in M30 just fail to rewind?
Found it I think.. Ill release a fix soon, it explains the failure on the M calls.
I notice too, like m3, it fails to rewind if there is no following line, so Im tacking that down as well..
  Rewind is fixed, download version 1.46 online now.
Thx for the bug
chicoxiba
Post by chicoxiba »
Yes the M calls are all going now. I get no more crashes. SWEET.
Just noticed if I type 1000 at the FRO field.. the code runs fast, I mean fast. But even with a low jerk setting it seems it gets too quick around the corners.
f
  lol, Feedrate override is designed to be limited to 0 - 100 %, I didnt set a routine to clip it,
Im surprised it worked, but as it realy controls time, if over 100 you risk going too fast
for your system and Jerk will be 10 times more than set for example.. so I suppose if one
knows it will work you could go to liek 110% or may 140%, but 1000? ..yeah, that'd be fast
alright.. lol
Users browsing this forum: No registered users and 214 guests
