reading Pokeys pins
gburk
Re: reading Pokeys pins
Post by gburk »
I guess I'm to old for this but any way I started the script edit and when I right clicked the led I got
Main_LED_0:XhomeTest
I got the same type of name on all the led's, but the buttons did look like I was getting the right names back
Thanks gary
Gary:
  SO to connect to that LED youd use
the name Main_LED_0 ,
led = Led("Main_LED_0");
led.SetStateMask(1);
the variable name is XHomeTest. Not all items have a variable name.
I think the statement XHomeTest = 1 shoud turn it on as well without
having to get an LED hook for it. Generally a variable named object can
be refered to in script by its variable name instead of getting a hook and
using that. Ill have to test thats true in the case of LED's, its been awhile
since Ive done screen edits.
Hi Gary:
I went back and edited to refresh myslf on how it works.
To set or get and LED's value, if it has a variable name, you can use
x = GlobalGet("MotionConnected");
print("Led = " + x);
GlobalSet("MotionConnected",1);
This will show you the motionconnected LED and set it to on if your in sim, replace
its varaible name with any you use and the globalGet / GlobalSet should work for you
for getting and settign any variable.
gburk
Post by gburk »
Ill try it I was confused as to how it knows which led  is ("Main_LED_0"); all the leds on the main screen had the same name except the :XhomeText The Estop led had Main_LED_ 0:Estop
Thanks gary
Gary:
While normally all LEDs will have names that are different, when the system see's they have a variable name,
it doesnt try to rename them to different primary names. this has to do with the rather complex system of naming
which is necessary as various modules could share a led name internally. At startup various id's are checkled in
order and apparently it ignores the naming once it see's it has a variable name instead.  (Its been awhile since
Ive been in there..).
  I tested the script I posted, should work OK.. Still dont know why the block didnt work, more testing req
gburk
Post by gburk »
Yes Art That script seems to work my led will flash and also it will turn off..
Thanks gary
PS I'm sure I will be back for more advice
gburk
Post by gburk »
New question go figure..
Is there a way to call a lib script from the button script...
Say I have a button it turns on the led and prints a message now in the same button script I want to call a script in the gcode lib like an mcode script I created Mcode330 or whatever ?
Thanks gary
gburk
Post by gburk »
You asked me to check the pokeys config program to see if pin 19 is being triggered and it is, still can't seem to get auggie to read a trigger on pin 19..
Thanks gary
gburk
Post by gburk »
Sorry art another question problem even though I haven't sorted out reading pins but homing problem
I see the homing led lights up if I trigger the home switch but it keeps flashing while its tripped the led doesn't say lit but flashes
But the motor does stop and reverses direction I assume its back off  the problem when the motor reverses it never stops just keeps running
in the opposite direction I have soft limits off.. and switch untriggered now..
any suggestions how to stop the back off distance?...
Thanks gary
Gary:
  You need to tell the pokeys to backoff the switch. Its a new setting in the pokeys engine config, if you test home on the
engine config page in Pokeys and it works, it should work the same in Auggie. Should be easier to test in the pokeys
software as it shows you what its doing on each stage.
Im doing some work in Auggie this week, Ill see what I can find on pin19, I need to hook one up to see..
gburk
Post by gburk »
Thanks art did get homing working,
mad a little progress can make a new button and led and get buttons to turn on and off the led also can turn on a relay with button press..
Still haven't sorted out how to read a pin if trigged.
I tried to look at any scripts you have installed but couldn't fine one I know you reading pin triggers like turning on the homing led when hit but couldn't find the script you are using to do it looked at the all the scripts I could find...
Also is it normal for the homing led to blink on and off when the switch to not triggered mine seems to do that, but when its triggered it stays lite no flashing...
funny because I have been having the same problem with the probe led in mach3..
Thanks gary
Hi Gary:
  Some functions like home are done by hardwire, there is no script. The pokeys for example reports homing as done or not and triggers
internal calls as its a priority function. The flashing shouldnt occur..doesnt here. Mine is either off or on. Ill take a look to see what may cause that symptom.
  For other inputs the software checks each pin and does an internal signal to Unblock using the words as we described earlier inj this thread. I just need to hook up something to trigger to see why it isnt calling you when the pin is triggered.
  Is it possible you wrote and forgot a script trying to light the home led? It woudl create a flashing as the system tried to reset it back to zero when not homed. Checking the software I cant fing anything to cause it to flash unless you checked an opion in its properties to tell it to flash when inactive
or something. (But its complex in there and I may be missing it..).
  When you actually home sucessfully, a signal is sent to scripts called "HomedAxis". So a block on "HomedAxis" should trip a script when a home occurs,
thought that doesnt tell you anything about which home it was. A call to GlobalGet( "Axis1Homed" ) will tell you if that axis is homed.
  You get a similar call when a pin goes active.. named MotionPin19 for example, though as I recall it can be off by a pin # as I used to count 0 as first pin.
I thought that changed but you may want to try "MotionPin18" or "MotionPin20" just in case soemthing is one off in there. Ill check this as soon
as I can get to hooking up a cable int here to use a pin.
gburk
Post by gburk »
I noticed if I use m8 or m9 its calling SetMistFlood()
I changed the code to getrelay and if its on with setrelay the m8 seems to turn it on, but m9 doesn't I know is going though the function to the turn off relay I have it printing showing turning off but doesn't go off... if i call m8 again it shuts off,  i tried my own m8 call function but looks like the SetMistFlood() overrides it..
also i see variables IOpins setup in system variables But nothing for MotionIO would that matter when you are trying to get the MotionIO pin status
also i will try a different # if you start at 0 then i try 18..
I also didn't write any scrips to turn on or off homing or the leds..
Thanks gary
gburk
Post by gburk »
forgot I ran the pokey configuration and the home pin works ok led stays lite or stays off no flashing..
Thanks gary
Hi Gary:
  Yes certain functions such as spindle, flood and mist are considered systemic and have their own script, it can be changed but not
replaced. Can you post the script your using for flood and mist, I may see something easier.
In the Motion library there is a global variable declared as Pokeys1 . global Pokeys1 = Motion();
So you shoudl be able to use
  PinState = Pokeys1.GetPinDig( 19 );
  I cant understand why its flashing. It may be the screen set has that LED set to flash in its properties. Youd have to open the DROPanel screen from panels to see if its led properties are telling it to flash.
