reading Pokeys pins
gburk
Re: reading Pokeys pins
Post by gburk »
After messing around some more Not sure if this is how you wanted me to set it up but
I created a global function with the buttons var name and that works when I press the button now.
and I added the call to  ZeroToPlate(1,3,100); from the global button press
but still won't run endless I run it in the scripter first...
and also still won't run the second engine.gcode() or any thing after that line...
gary
gburk
Post by gburk »
art yet another message hope you like reading  :D
I got the script to run some of the problem was I copy this  xcor = GetAxisPos( 1 ); from the doc file and just realized it needed the enging  xcor = Engine.GetAxisPos( 1 );
now the script will run to the end...
still some strange behaver I still need to run the script first though the script RUN to work,
if I press button and let run to the full distance entered for the axis I would have to do the script RUN first before every button press and I find if I have X-25  it stops at different distances usably at -28 after the first run.. I find the same when reversing if 1 have X3 It will run to X3 the first time but run again seem to stop at X0 this is all without hitting the probe....
if I run the script though script RUN then do a button press X-25 Axis starts running then I hit probe it stops ok pauses and then starts to reverse I hit the probe it stops and ZEROS the X axis.
the strange part is as long as I hit the probe while axis is running, I only have to run the script thought the script RUN Once as long as I keep hitting the probe while running I can just use the button.
here is the latest script
global mytable = table( "X", "Y", "Z","A" );
global ZeroToPlate = function(axis,dir,feedrate)
&nbsp; if ( axis < 1 || axis > 3 )
&nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; print("Error: Axis can only be 1 X, 2 Y, 3 Z");
&nbsp; &nbsp; &nbsp; return;
&nbsp; &nbsp; }
&nbsp; print("a = ",axis);
&nbsp; print(mytable[axis]);
&nbsp; axis = mytable[axis-1]; //X = 0 Y = 1 Z = 2 A = 3
&nbsp; print("d = ",dir);
&nbsp; print("f = ",feedrate);
&nbsp; GlobalSet("ProbeInvert",0); //set probe to normal state
&nbsp; string = "G31"+axis+"-25" + "F" + 100;
&nbsp; print(string);
&nbsp; Engine.GCode(string); //probe 25mm down in Z
&nbsp; block("MotionStill"); //wait for all motion to stop, no system delay for this.
&nbsp; pinstate = Pokeys1.GetPinDig(19);
&nbsp; if( pinstate )
&nbsp; //if( !GlobalGet("ProbeHit"))
&nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; print("No hit on probe ..Try again closer to plate.");
&nbsp; &nbsp; } //we didnt hit the probe during the move
&nbsp; &nbsp; print("hit on probe");
&nbsp; &nbsp; sleep(0.5);
&nbsp; GlobalSet("ProbeInvert",1); //invert probe switch
&nbsp; string = "G31"+axis+"3" + "F" + 100;
&nbsp; Engine.GCode(string); //probe upwards slowly till switch releases
&nbsp; xcor = Engine.GetAxisPos( 1 );
&nbsp; print("xcor = ",xcor);
&nbsp; //if( GlobalGet("ProbeHit"))
&nbsp; {
&nbsp; &nbsp; &nbsp; print("Zero Axis, probe complete.");
&nbsp; &nbsp; &nbsp; GlobalSet("Zero1",1); //this will zero axis #3-Z (the numbering starts at 1 for X in zeroing
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; //function even though some other functions start with 0 for X
&nbsp; }
&nbsp; &nbsp; else { print(" Error in touchoff" );
&nbsp; };
thanks gary
Gary:
&nbsp; I think I see the problem. If the probe isnt hit the engine is left in Pokeys control
with the engine in a probe state. Thats weirding things up internally. It probably
explains the final problem you have any why if you hit the probe every call all
is fine. I will fix this tomorrow by ending the probe state in the engine when MotionStill
is signaled if probe is in effect. That should fix the issue. I appreciate your work in defining
it. Ill notify on this thread when I post the fix.
Gary:
&nbsp; Auggie 3.5 is online. It fixes a problem where if the probe didnt hit, the engine
was left in a probing condition until the start of the next move. Now, just prior
to MotionStill being signaled to the scripts, the probing , if in effect, is terminated
properly so its ready for any command.
&nbsp; Let me know if this fixes your problem..
gburk
Post by gburk »
ok art will try it, thanks
I think the most annoying part right now is having to run the script first in script RUN before the button press
and I may have to run it again after running probe it seems to random. I may get 2 or 3 probe runs before I have to run in the script RUN.
a couple questions on the screen edit.
if I change the font size it always converts back to 9 doesn't seem to want to stay at the size I entered..
also is there a way for a button to swap to a different screen say I want a button for probing and then that button will show a probing screen...
Ok Tried it out still have to run in script RUN first it reacts a little different now,
if I let run to the end in -25 direction first run engine I get the messge probe stop before complete I then zero the axis and won't run again until I run it again with script run, now say I run the -25 again I go a Radom distance and keep the probe shorted I have the reverse set to 3 and let run till end I get the same message probe stop before complete but funny thing I don't need the run it again with script run just a button click will rerun now.. the only real problem I see reversing is a lot of time if I don't release the probe it seems to just keep going I have it go as far as 20.. not good if maybe a probe got stuck or for some reason&nbsp; stayed grounded won't break probe in that direction but would slam the axis if you didn't have that much travel distance..
when the probe is triggered and released that seems ok&nbsp; &nbsp;
it does stop and zero the dro correctly.. and for the most part a don't have to rerun the script before a button press
hope this helps
thanks gary
Gary:
&nbsp; Try saving the screen after changing the font, as I recall that can be a bit difficult to keep stuck..
&nbsp; You can use panels with multiple pages...but I dont think I made a facility to swap full screens.
>>if I let run to the end in -25 direction first run engine I get the message probe stop before complete
&nbsp; Thats a normal message if the probe doesnt hit.. though Ill change that to "Probe motion complete, no hit."
&nbsp; So this is the button? And it wont run again till after a script run from the script tab?
&nbsp; So if Im reading this right, you try it and hit the probe after a short distance, it stops and reverses.
You keep the probe held, so it continues raising until end of probe up command, stops with
same termination message, and button now works fine. ?
&nbsp; It shouldn't be possible for it to move more than the commanded motion.. If the probe doesnt
release it should only go back up to start zero?
it does stop and zero the dro correctly .. and for the most part a don't have to rerun the script before a button presshope this helps
&nbsp; So do I have this right, problem only seems to happen still if the probe doesnt hit
during the probe command?
gburk
Post by gburk »
..You can use panels with multiple pages...but I don't think I made a facility to swap full screens.
ok I know multiple pages, I thing is when you create one like the Diags pages is if I change the text to Probing I need to make the button big or the text will be cut off
only show the bottom half of the word
thought about creating a dialog but your examples are not in the lib. and I tried messing with it but seems like some of commands you used in the video are not working off the top of my head one was the buttononoff..
.. So this is the button? And it wont run again till after a script run from the script tab?&nbsp;
Correct.
to be clear the button does run on every press all the print statements display the messages on screen just no motor movement till I re run the script tab..
..&nbsp; So if Im reading this right, you try it and hit the probe after a short distance, it stops and reverses.
..You keep the probe held, so it continues raising until end of probe up command, stops with
..same terminati on message, and button now works fine. ?
..&nbsp; It shouldn't be possible for it to move more than the commanded motion.. If the probe doesnt
..release it should only go back up to start zero?
That what I would think but I have has the dro's go as far as 20, and the reverse distance is hard coded not a var and is set to 3..
so I have no reason for this one, so far its only if the probe it not released. I will try later and swap the directions go to pos then neg;
.. So do I have this right, problem only seems to happen still if the probe doesnt hit
..during the probe command?
It seems that way so far when probe is hit stops then reverses and when I release the probe it stops and then zero's the axis dro..
Ok I tested it going pos then reversing to neg exactly the same results, except not if if runs all the way to 25 I have to re run the script tab
and if I hit the probe and it reverses to -3 its fine don't need to re run the script tab.
so looks like as long as there is a probe hit its ok.
But this doesn't explain why I need to run the script tab first to get things going I don't see anything in the script that looks like the problem..
are you going to do away with this command&nbsp; GlobalGet("ProbeHit") and stick with the pin19 check?
Gary
Gary:
>>are you going to do away with GlobalGet("ProbeHit")...
&nbsp; No, they have different uses. ProbeHit is just and indicator that
the last probe was sucessfull and the cooridnates stored can be validly read
as that hit point. If fals,e the last probe wasnt sucessfull.
Your pin19 check is just a check realtime on pin19. Probehit will work
no matter what pin is used.
&nbsp; It sounds like something bad is still going on if a probe isnt hit..
Ill have to dig into it.&nbsp; it may take a couple days as Im in the middle of some
other code.
gburk
Post by gburk »
no problem take you time I'm in the middle of getting the routing done on the board I'm working on want to get it out tomorrow to have a prototype built..
gary
gburk
Post by gburk »
Got back to testing :
I seem to have a issue with homing also seems when I first boot auggie and then do a home it always seems to set the axis to a value other than 0 then if I home again its ok sets dro to 0..
also I don't think GlobalGet("ProbeHit") works correctly I get the same value if hit or not,, that's the reason I went to checking pin19...
also having problem figuring out the way mach and work cord work...
I created a small global script to move the x-1 and then to x1 I&nbsp; home the x first then jog x to say 2" and then zero the work cord for x, now i run the script then hit the button
it seems to run fine go's to -1 then back up to 1.. now if I zero the x again and press the button it runs to -2 and then back to 0 but the mach cord seems to go -1 and then up 1 they seem to loose sink.
also if I set the work cord to .250 after a move to -1 in a script then send a move to 1 I would think it would move to 1 but not finding that the case... never moves to 1..
also not sure if I am correct&nbsp; but myxmachinecoord = Engine.GetTruePos( 1 ); should return the mach cord
and usercoord = Engine.GetAxisPos( 1 ); the work cord. I find both to return the work cord.. same values..
Thanks gary
Hi Gary:
&nbsp; Ive confirmed some of this and fixed it already. It seems I added a few bugs in adding probing,
and in the case of GetTruePos , I had never used it so I missed a section I should have rem'ed out
to stop offset comp. , I will put out a new version tomorrow after I run some verification tests.
Gary:
&nbsp; New Auggie is online..
Notes:
&nbsp; I found and fixed a problem with Probehit and with syncing after a probe. Problem was
the planner was syncing before the final position was read. I tested this with a script..
Engine.GCode("G31X50");
if( GlobalGet("ProbeHit") )
&nbsp; print("Probe was hit");
else
print("Probe not hit");
Engine.GCode("G1X0");
&nbsp; It is consitant and shows probehit or not, and always returns to
0.
&nbsp; I cant repeat the homing issue, mine homes and reads all zero's afterwards.
The work coordinates seem to be fine here, I tested with a script that
moved from -3 to 3 three times. It stops at 3.0 , if I then zero the script
still moves from -3 to 3 as new coordinated. Work coordinates are the normal view,
the machine coordinates are the raw coordinates the pokeys sees itself at, the
work coordinates are, like in mach3, just that with offsets applied.
Let me know how you make out..
gburk
Post by gburk »
Ok Seems good haven't run a lot of test but no problem now when axis runs to end with out a probe hit I tested your code in the script run..
and I ran this thought global with a button press it also ran good no problem, running and returning to 1,
still have to run the script in the script run before It will run with a button press but now I only have to run it once, so that's good, but is there a way so it doesn't have to loaded into the script edit and run first?.
I had to invert my probe other wise it was always&nbsp; triggered,,
also when probe is hit the axis doesn't stop dead it moves past the probe hit, it looks like enough to crash into the switch's..
will test some more with some added code to see if backing off will&nbsp; see the switch being released ok.
I'm using Inch not metric.. hence the different numbers from you code.
&nbsp;
global ZeroToPlate = function()
print("probe test");
Engine.GCode("G31 X-3 F100");
&nbsp; ProbePos = Engine.GetAxisPos( 1 ); // Get probe position
&nbsp; print("Probe Position = ",ProbePos); // show probe position
else
Engine.GCode("G1X1");
gary
gburk
Post by gburk »
Ok the problem I'm having is - if I have a touch off&nbsp; plate say .250 thick now I probe to plate then set axis dro to .250 at plate&nbsp; then I want to retract to 1.0 when I do a g1 x1 it go's to 1.6 even higher over 2.0, it seems not to know its sitting at .250 after I set the dro to .250, if I remember right that would work in mach3 or you could set axis to 0.0 and move touchplate - 1.. then set dro to 1, making any sense?.
Gary&nbsp;
Gary:
>>also when probe is hit the axis doesn't stop dead it moves past the probe hit, it looks like enough to crash into the switch's..will test some more with some added code to see if backing off will&nbsp; see the switch being released ok.
&nbsp; This is typical with probes. You dont want to simply stop, steps could be lost. So typically when the
probe is hit, it trips to a deceleration phase, then stops. That why if you then get the probe hit points
from a script you'll see they are not the final rest position. Two things you can do for that is to either
probe at a lower feedrate, or set axis acceleration to a higher value.
&nbsp; &nbsp; Normally Auggie is 6th order for motion, BUT when a probe trips to hit status during a probe,
the pokeys switches to internal planner and slows down based on the setting of accel. Its a mach3
type of bang bang slowdown trajectory. The slower you go the faster you stop.
&nbsp; That why typically one would feed in a little quick, the plate would be on a spring so allow for the
slight crash, and then you'd withdraw very slowly to stop one step within leaving the plate.That would
be considered zero.
>>k the problem I'm having is - if I have a touch off&nbsp; plate say .250 thick now I probe to plate then set axis dro to .250 at plate&nbsp; then I want to retract to 1.0 when I do a g1 x1 it go's to 1.6 even higher over 2.0, it seems not to know its sitting at .250 after I set the dro to .250, if I remember right that would work in mach3 or you could set axis to 0.0 and move touchplat e - 1.. then set dro to 1, making any sense?.
&nbsp; That ones weird. I specifically tested that here to ensure it still moved to proper position
after a hit. Yes, you should be able to set the dro to .250 and then G1 to x0; Ill test that
again tomorrow to see what might be going on. This is on the work coordinates tab right?
Not the machine coords tab? Sounds like we're close anyway...
Users browsing this forum: No registered users and 148 guests
