Version 4.88
Version 4.88
Hi guys:
Version 4.88 is online, it fixes hand indicators not stretching. It also
adds British Sprockets data for the simplex through triplex chains..
Re: Version 4.88
When I try to install, it says INTERNAL ERROR 11: Cannot decompress setup program
Re: Version 4.88
Hi Steve:
Sounds like a bad download. I just downloaded it here and it installed fine. So try again
and see if it gets corrupted again..
Re: Version 4.88
I think that is the third time that has happened.
Maybe one of these days I'll remember to download it again before I post.
Steve Fox
Steve Fox
Re: Version 4.88
np, always worth a test.. :)
ARt
ARt
Re: Version 4.88
Many thanks for the chain update :)
Re: Version 4.88
No problem, thanks for the data. Take note though, the data was for the chain, not the sprocket, so the thickness value wasnt there. I interpolated it from the US versions converted to metric as a .01" clearance on the smallest size chains, and .125 on the largest ones as I recall,
so check your thickness value iof its important to your requirements. I cant promise its all accurate, many websites massage the data to make it
slightly incorrect on purpose..you just never know till its tested.
Re: Version 4.88
On the http://www.gearotic.com download page, it still is "Current Release 4.67"! Where can I find the download link for 'Version 4.88' please. Thanks.
Re: Version 4.88
3dsupra;
You can download the latest version 4.88 here ( http://www.gearotic.com/downloads.html ) called (Current Development 4.xx) on the main download page.
Re: Version 4.88
There is a file on the downloads page called "Changelog.txt", check it periodically as it tells you the current "development version" number,
what has been changed (and when) and what has been bug fixed. From that log you can decide if you should download a new version. If the changes listed
dont really affect you, ignore the download, but if you see womethign you like, then just download the dev version, install it and your good to go.
Users browsing this forum: No registered users and 201 guests
