Art;
Do you think a "Reset to Default" button in all working tabs of Geraotic II would be benficial? I get many offline posts to where problem would be easily fixed if such a button existed.
Cheers pal
crashing
Re: crashing
Re: crashing
Chicken or egg issue. If you have that problem you cannot run the program, so you cant press the Reset to Default button.
A solution is in the works though, in future the program will recognize it wasn't shut down properly
and if so will ask if you wish it to reset the registry to default to cure any ill's. Should be in the fall
release.
release.
Re: crashing
When making gCode for a Chrono deadbeat there are a number of components and the program wants to make each one 0.5 inches by default, while I will generally make them 1/4 inch thick. If I set the first one at 1/4 the program will revert back to 1/2 on the next component of the escapement.
You may have done this on purpose and if you did OK - I now know what to watch for but it would be nice that when generating gCode the program stayed at the same thickness of material in 2.5D generation instead of reverting to a default of 0.5 thickness for each new component that is being generated.
Not a buggy
Not a buggy
Re: crashing
In the fall that will happen. The whole concept of CNC in G2 is going to change to a much better system with each type of maching having its own toolbars and options. Ill make sure that the end thickness is something that holds from piece to piece. (Much of this is already in the works but its a very large switchover so youll see it happen mostly all at once in a fall release.
