Colibri
Links to Youtube videos
Ken_Shea
Re: Colibri
Post by Ken_Shea »
Thats just absolutly brilliant.
7 losers didn't like it, how in the world  ???
Steve Fox
Re: Colibri
Post by Steve Fox »
I tried to have a conversation with him and my opinion is that he doesn't have a very good attitude.  I've run into so many artists like that that I have come to expect it.  Maybe others have tried to talk to him, too.
On another note, If you look at the video closely, there are three gear sets in there that have a daisy shape and end up with a 2:1 ratio to drive a cam.  The bottom one runs from 00:29 to 00:38 on the video.  Is there any way to do that in Gearotic?
I'm drawing up my own version of this.  I've gotten most parts to work in Inventor, but they do some funny stuff in there that doesn't have anything to do with reality.
Re: Colibri
Steve:
  >> sets in there that have a daisy shape and end up with a 2:1 ratio t
Yes, they are planetary epicycloids, the Cage gears in planetary mode, same thing.
chrome700
Re: Colibri
Post by chrome700 »
Steve Fox wrote:I'm drawing up my own version of this.  I've gotten most parts to work in Inventor, but they do some funny stuff in there that doesn't have anything to do with reality.
Does Inventor do a good job with cams and followers? Ive not spent a lot of time with it, but Fusion360 doesn't seem to do them well.
Steve Fox
Re: Colibri
Post by Steve Fox »
I don't think it does a good job with cams and followers or gears.
It may be me, but all I can get it to do is follow one surface for a cam.
If a cam is made from more than one surface, it gets lost.  All my cams are more than one surface.  There is a cam generation program that appears to work using pregenerated cams, except I can't figure out how to generate the kind of cam I want or even if it is possible.
As for gears, it doesn't see teeth.  You can only tell it which objects are "meshed" and the ratio between them.  If you aren't very careful, the teeth overlap with no solution.
I do have to say that as far as shafts,bearings, screws, etc., it does a reasonable job.
I have been able to work out the wing mechanism on the hummingbird.  I think it is accurate enough to build it.  At least, it seems to be, based on the trouble I had getting everything to work together.
Steve Fox
Re: Colibri
Post by Steve Fox »
ArtF wrote: Steve:
Thanks Art.
KevinO
Re: Colibri
Post by KevinO »
Hi folks,
Just joined the forum and while browsing I came across this thread regarding the Colibri Hummingbird sculpture.
I built one several months ago (picture attached) and it's a real show-stopper when people come to visit. I added an electric motor drive and it really works well.
With over 400 parts, it takes some time to build but I found the plans to be excellent. The .dxf files for all wood parts are also provided with the plans.
I found the designer, Derek Hugger, to be extremely helpful during my build and very promptly answered any questions that came up.
I'd like to try my hand at designing a kinetic sculpture and I'm sure Gearotic 3.0 will make the project easier to design and visualize.
Kevin
