Spoke and hub turn but gears don't
danmauch
Post by danmauch »
I d/led the latest version. I selected a couple spur gears and was playing with spokes. When you simulate everything works as it should until you move the slider all the way to the fastest position. When you do this the spoke and hub on the right hand gear turns but the gears don't.
20th Anniversary in CNC
Re: Spoke and hub turn but gears don't
Dan;
I see the same visual effect here when the speed slider is set too high, however I don't beleive it is a problem, it's simply a refresh rate artifact caused from my video card. Slow down the simulation speed with the slider in G2, I think all will be fine then, it is here anyway...
  As bob says, not really a bug, its just your turnign so fast that each update is a full rotation, so it looks stationary at certain speeds. Just like in real life. :-)
