Hi,
I know there is an export function as I have read a few thread in which exporting to STL and DXF has been mentioned but where is it?
Confused
Nic
Export function?
Re: Export function?
Also the search function now keep refering me to this thread :D
Nic;
In a nut shell, once you have created your gears in GM, select the gears you want to export from the project screen one at a time or hold Shift key down to select multiple where they become highlighted in blue, next select the output manager. All the gears you have selected should now appear in the output manager tree. Select the output function desired , then select one at a time or select copy to all gears to export them all in one shot. There is a tutorial pdf available located in the "about" icon top right in GM, click and select help file to view it. Hope this helps...
Bob :)
Bob :)
Thanks Bob I knew it would be obvious.
