Version 3.01
Re: Version 3.01
Awesome.. nice cuts.
Did the error go away? Did it happen when you tried to run the install or the program afterwards?
Re: Version 3.01
I am not able to install, the error message pops up and
then exits the install program...very weird...
R
R
Re: Version 3.01
Got it to install by disabling my Norton Antivirus program...
Thanks....
Thanks....
Re: Version 3.01
These days some consider it the Norton Virus. The free stuff that comes with Windows (Defender in W10) is more than good enough as long as you're not into the type of site that generates hordes of popups and don't click on those click-me links in emails. If you do then NAV probably isn't good enough either, and you need frequent backups to a device that you normally keep disconnected so the extortionware won't encrypt it. Better yet, two disconnected devices that you alternate
Re: Version 3.01
Well, that was weird. I wanted to play along with the latest video and tried to create an eccentric gear for an example. When I click Tooth Wheel the teeth appear, then about a second later disappear. I tried changing the number of teeth and the mod, still does it. The settings are pretty random, just what was left over from last time. A screenshot is attached.
Re: Version 3.01
I'm also missing all text in the Job section, so another screenshot.
This is a laptop, 1366x768, i5-5200U with embedded graphics and the latest Intel driver on W10 64b Insider Preview 14955.
Re: Version 3.01
Try a standard spoke, Im interested if the new spoking is screwing the teeth..
Re: Version 3.01
Thx, Im seeing the bug now.. Im searching for why..
Re: Version 3.01
I think Ive found it, a new version 3.011 is uploading as a test.
Re: Version 3.01
It's circle2 spokes, one of the standard ones. I haven't graduated from the school of fancy spoking yet.
Guess I'm just good at breaking things.
Re: Version 3.01
The eccentric gear example works!
Re: Version 3.01
One of the downloads allowed for imperial measure and the latest 3.011 doesn't again, its metric only.
Re: Version 3.01
Sorry about that, too many small fixes lately and some bugs have crept in. Ill check it.
