52 tooth XL pulley 4th axis problem
Post by Dan Mauch »
I have designed a 52 tooth XL pulley. Every time I click on 4th axis machining I get and Open GL error. I'm using version 3.0200
Dan mauch
Re: 52 tooth XL pulley 4th axis problem
Hi Dan:
Just tested here with no trouble on a 52 tooth xl..
Does it work OK on smaller tooth counts?
Post by Dan Mauch »
I tried it on various smaller tooth pulleys and the same problem. Similarly, I tried run GM3.02 on my notbookk and it too gives me the open gl error.
Can it be the tool you have selected having some weird setting?
Does the error go away with any of the tools? Is this a slit saw
or milling tool being selected as default?
Post by Dan Mauch »
My bad! When selected the 4th axis the tool was too large. I thought that when i selected the 4th axis i would be able to select the correct tool. So what surprised me was that instead of getting a tool to big error I got the Open GL error. So I raced down the the wrong rabbit hole chasing a non problem. Last night I figured out that the tool was too large and changed it. To avoid confusion by others I would suggest that the user would get a tool to big error instead of the opengl. Otherwise thanks for a great program.
ArtF wrote: Dan:
Hi Dan:
  Thx, added to my bug list for repair.. :)
