Version Update
Version Update
Due to some errors in profile shifting, the dev version has been upgraded with new control code for shifting.
In this version is the mostly complete gear train calculator. (On the round gear page) I will do a video on its use
soon when its complete.
This version is really so I can run some tests with John S who is testing some code for me, but if you DO use
it please let me know of any issues as it contains a great deal of new code.
Re: Version Update
The material choice is still an issue
Seems to me if I choose brass for the shafts as default, all new shafts should be bass
And if I choose red plastic for the Evolutes then all new gears should default to red plastic.
Then If I rename gears or a shaft in the tree then new issues arise.
Something is not quite right, but I cant seem to get my head around it.
Project tree re-sorts itself but not sure why.
If I add a pinion and then add ratchet then hit undo, both ratchet and pinion get erased.
Adding ratchet seems to me like I am adding it to the wrong side visually, I have to put it on the back (top of screen) to see it in the front after placing it. Am I looking from the bottom up when I add the ratchet?
Hitting reset I would think the rotation angle should go to zero.
If I add a pinion the rotation angle is a huge number.
Not following what this is telling me.
Not to be picky, but I'm getting old and things irk me. ;D
Re: Version Update
I agree, I;ll check it.
The only sorting it should do is if shafts change. Make sure the tree is set to sort by shaft. ( small selector top of tree on left.)
Thats because a ratchet is a single device, it isnt two. Its special in that regard, but shoud be intuitive if you get used to the thought.
Look to the head, when you place it, youll notice the heads face it at the top, it means thats the front. Its a matter of what direction its looking in from,
backwards to one person is forwards to another, but if you always look to the head it becomes intuitive..
Really an internal message for me, it will soon change to what youd expect as I add ratio tracking..
Re: Version Update
Cant find a material error, it seems to keep on mine. ( Though when you first place it , the material will "look" wrong
because its currently selected. Deselect it and it should show the material thats set in the options.
Just discovered a bug in the recoil and graham escapements, fixed and updated a few minutes ago, ( The pawls were broken).
Re: Version Update
I believe, because I am always downloading the new versions on a laptop 32bit Win7.
That most of the issues are 32bit and laptop graphics related, as I don't have the HEAD visible on my screen.
But the HEAD is visible on the 64bit Win8 system. Have not tried the material and sorting issue on that as of yet. Not one at sitting at a desk, to many projects to do in the shop. :)
Re: Version Update
Really? Wow, I hadnt heard of that, Ill list that for investigation..
Re: Version Update
I would have bet (*and lost :-\) that I referred to a graphics issue on this laptop within the first couple of GT versions out.
*went back and looked at my old posts, could not find it. (another sign of ole age) :'(
Re: Version Update
Got no trouble on my old laptop but just checked and it's 64 bit which surprises me.
Off to install it on an old machine computer that's on XP, gotta be 32 bit ?
Runs this old crap controller software called Mach 3, you might have heard of it ;D
Mind you it is better than Mach 4 :'(
Nottingham, England
Nottingham, England
Re: Version Update
Dev version will not install on XP. tried two machines and get "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem"
but it doesn't.
quite an old machine, no network or internet connection so old .net framework ?
but it doesn't.
Nottingham, England
Nottingham, England
Re: Version Update
I don't know if this is any help to you, but I have a partition on my Mac that is accessed by Parallels and runs Windows XP. I have installed the latest dev version without any problem. There are some peculiarities but the design portion works fine.
If I get system info this is what it says.
Re: Version Update
The Peculiarity that I referred above to is the "options" button. When i click on either the Globe icon or the gear icon they cause the screen to lock up on me and I have to hit the escape to return to an operational screen. As a result the options function in inaccessible to me.
Re: Version Update
The configuration error is usually that the vcdistx86.exe wasnt run on that machine. Try running that, its in the folder for gearotic.
Ill check the options menu to see what may have changed. Sorry for all the bugs this version but quite a few htings are changed, take me a
couple fixes I think to fix it all up.
ARt
ARt
Re: Version Update
I could not find a file vcdistx86 but did find the following and ran it -
/Volumes/C/Program Files/Gearotic Motion/vcredist_x86.exe
The Option icon still freezes the screen and require an "esc" to get it working again. All my other tests worked. the far right icon for version isn't happy either an requires a command-option-escape combination to free up the program. Once that combination is applied I get my name and version identified as 1.07.
PS No need to apologize for the bugs - gives me something to test and I am very excited about where the program is going.
Re: Version Update
VRCEDIST_X86.exe cured the problem.
GT now runs and I have the head on screen and selecting different views moves the head.
This is on two old clunkers.
Don't apologise for the bugs - just fix them ;)
Nottingham, England
Nottingham, England
Re: Version Update
Now that options thing is a weird one, as is the version thing..
If this still happens on next version John, Ill make a special version just for you that does some tracing to see if we can track it down,
its one of the weirder ones Ive heard of, and Ive heard some pretty weird stuff over the past decade or so between Mach3 and GM.. :)
Users browsing this forum: No registered users and 180 guests
