right hand and left hand helical.
kevin long
Post by kevin long »
i am having trouble getting a left handed helical gear in gt.  i have left the right handed boxes unchecked as well as checked and the running simulator shows them both to be right handed either way.  any ideas of what i'm doing wrong here?
thanks !!!!!!
John S
Re: right hand and left hand helical.
Post by John S »
What are your shaft angles ?
Nottingham, England
kevin long
helical angle is 45 deg.  shaft angles are 90 deg of each
John S
Post by John S »
Then they will always be both RH.
If they were in line i.e. shaft angles at 0 degrees then you need a right and a left to mesh.
Nottingham, England
The left/right labels I believe are bugged and backwards..Ill fix that up. Also, you need to press
regen after changing the selection.. (Ill fix that too.. )
